New intelligent lightdimmer for B&O remotes
Answering myself...
The web site mentions Wall mounted or Floor mounted..
 Anyway... I have just ordered a pack of 3 and will order more if I am happy.
p.
A new and even nicer dimmer is now available:
Do anybody have pictures of installed  Raone SmartDimmer ?
I'm wondering can I install smartdimmer insted of my existing wall swich ?
Now that's a showroom installation 😎
Looks good otherwise.
My query about both of these solutions is that of the wall switch.  I realise for my ceiling light, I could bypass the wall switch and control it only with the Beo4.  The device woul dbe mounted on the ceiling - so the touch switch would be useless, unless I had a ladder!
Ideally, I would like to retain the option of turning the light on/off/dim from the wall.  How else would you find a Beo4 in the dark?!
I can see a possibility of using a Z-Wave wall switch with the RAOne.  Does anyone have any other ideas?
You can mount the AluDim near the wall switch and control (dim and switch) your ceiling light via the black button  of the AluDim.
Stefan
Does anyone has experience with this product:
http://cms.jbmedia.de/index.php?option=com_content&task=view&id=95&Itemid=74
You can order it in a B&O version with plasma protected receiver. I'm willing to order one but I'm a little afraid it won't have the same IR reception as a LC2.
This makes it even more interesting for me, since you can make your existing light switches B&O ready.
http://cms.jbmedia.de/index.php?option=com_content&task=view&id=79&Itemid=74&lang=en
Does anyone know why the links to the shop do not work?????
Try
