New intelligent lightdimmer for B&O remotes
link
The RAone SmartDimmer is perfect for creating a specific mood anywhere in your home. This Danish designed and developed light dimmer is operated by a light touch of the finger-touch panel. With the INNOVUS SmoothRemote, a B&O remote or a Logitech Harmony 890PRO or Harmony895, you can operate the light dimmer from your sofa or from bed.
The RAone SmartDimmer is more than a light dimmer. It is your entrance ticket to a world of opportunities for smart-controlling your home. The RAone SmartDimmer was created as a part of the INNOVUS Home Automation system, by which lighting, heating and security are controlled via central switches or a remote control device, providing convenience, security and energy savings.
The RAone SmartDimmer in the children's room
The RAone SmartDimmer helps your children fall asleep. Two light touches of the light dimmer and the light will fade slowly over a half hour while the children fall asleep.
The RAone SmartDimmer as energy meter
The RAone SmartDimmer has a built-in electricity meter that measures the electricity consumption of the lamp to which it is attached. Together with INNOVUS House Control, it provides a valuable overview of the energy consumption in your home. (The electricity measuring function requires INNOVUS House Control.)
It should be the same.. Notice that is the remote and not the IR reciever that make the difference in reciving the signal . Beo4  are much "stronger" compared to others remotes.
It´s possible to ordre in english (just push on the GB flag at the top at the screen.
Does this work in the US and will you ship there?  Also, can it be programmed and how so I can have multiple in the same room.
 link
Technical specifications
Voltage 220-240 V AC
Max. wattage 1800 Watt
Load <1 Watt
CPU ZW0201
Radio frequency 868 MHz
Z-Wave device type Routing slave
Size (diameter x depth) 85 x 27 mm
Installation:
The unit is designed for indoor use - rating IP20
Operation:
Radio Z-Wave EU
Local Finger touch
Have been using this dimmer for some time.. works perfectly! Superb IR reception!!!! The Dynalight dimmers are crap compared to this dimmer!
Karel what is the price of this masterpiece?
Karel, can you also switch lights off or only dimm with it? I have several Megaman Dors 4 steps dimming lamps at home and it only works when you really can turn the electricity off to the lamp at once.
