New intelligent lightdimmer for B&O remotes
sounds very interesting
can you use it for electronic transformer to?
I have looked at the user guide and makes mention of low energy bulbs, but can it be programmed like the LC2 for specific use for this so it only works in the on/off mode? I could see no reference to this in the operation section of the guide.
DaveL
Can they be programmed like LC2, with 10 different light moods? (LIGHT+1, etc...)?
Where did you guys find the user guide?
 p.
To summerize: everything the LC2 can do this dimmer can do to.
Manual at:
175 Euro for 3 the above link implies
Seems very cheap compared to the price of LC2's before they ended production.
Craig🙂
Notice that the next version of the RAone lightdimmer that  comes in this month (marts/april)  will could be used  with the new ligtning tecnology called LED or OLED.
LED lamps will only be possible to dimmer with new generation of lightdimmers.
 A LED lamp  that gives the same light as a normal 40 Watt bulb, are  only using 5-7 watt and normal (old) lightdimmers will not could  be used, becouse the ampere (A) is to low
Just bought the 3-pack. =) Looking forward to see if they are as good as the LC2 regarding IR-reception.
Is it possible to activate the 30-min dim by the remote?
/Ola
So from the specs it seems there is no US product yet?  Any idea when the US version will be available and at what price?
FYI i got my 3 dimmers today, and unfortunately i cant seem to get any of them to work. One does not work at all, the other two turns on the lamp at about 50 % but does not react to touch or anything. Can anyone help with this issue? As i am aware, they should work right out of the box and that is also what is mentioned in the userguide. Does anyone have them up and running?
US version?
please?
-michael
