Greetings new guy who just purchased one of my longtime wanted speakers, penta. After spending lots of looking I have to say I am mostly confused about what B&O vintage gear, other than those listed in the product description on this site, that I can use with my active speakers. I think I am correct that I need to use power link to connect but not sure I'm clear on much help. Hoping someone can lead me in the right direction for a great vintage receiver to match up with my Penta's. Thanks for your patience.
New guy, probably old question
Hello and Welcome!
BeoCenter 9300 or 9500 is what I'd choose personally.
Failing that, a BeoMaster 4500.
However, that's only my opinion - you'll get plenty more on here!! 😕
Lee
I like the look, sound, and flexibility of the pizza box systems. Depending on which Pentas you have, the 5500 and higher could be a perfect fit.
I have the Penta 1
Ok, then with no powerlink on the Pentas, the 5500 and higher would be just fine.
You want a system with “speaker link” option for the full use of the display in the Mk1 penta. Like Dom said, a 5500 system would be nice. Or maybe a Beocenter 9000?
