New Google TV remote with beovision 10
Hi all,
I have the new Google TV connected to my BV10. Everything works fine. I can use the Google remote to change the volume and to turn off the TV. What I don't know is, how to power on the BV 10.
Have someone of you a idea?
Thanks, Peter
Hve you downloaded BUTTON MAPPER, mine works well turning off the TV and Goggle TV at the same time
Thank you! I will try BUTTON MAPPER :)
Thank you, I have looked at the tool. It is for the phone. I am looking for the possibility to turn on the Beovision 10 with the GoogleTV Remote. Turning it off works perfectly. If someone has an idea how I can turn it on via the remote it would be great.
Button mapper is a sideloaded application for google TV!!
It gives you a picture of the google TV remote and how to map each button for a specific purpose,  So you can rename the 'netflix button for example
https://www.howtogeek.com/693763/how-to-remap-buttons-on-the-chromecast-with-google-tv-remote/
It works on my device perfectly controlling an Avant 55 and google TV with chromecast. Make sure you update the google TV  ( a software upgrade came last week, please alsonote the upgrade for the remote software has to be enabled from the settings menu in google TV
