New Deezer App Beoplay V1 / BV 11
Opened the app on my BV12 and Avant Mk 1 - both seem to be the new (er) updated app
And lo and behold, it looks like a modern app!
At least at very passable alternative to using a smartphone,  that much I'll say.
A touch slow in loading pages, but certainly well laid out and a good choice of options.
A pleasant surprise, though I haven't tried the native app for years - my recollection was that it was god awful.
Millemissen wrote:
Please do help me!
Just tested on my BV Avant.
I do see NO changes there from how it was before - it is just as buggy as ever....totally unusably.
What are you doing, that I am not?
Note: I have no Deezer account...if that should make any difference.
(Assigning a button is not a problem....never was.)
Deezer redesigned the desktop app (at least for Mac OSX) very recently.
The new smart TV app has a very similar look and feel now.
Maybe it was all part of the same process / rollout.
Still a bit puzzled by this.
The app on my Avant looks like in the picture from Hiort, but it reacts terribly slow.....no fun, at all.
I’ll have to try on my V1 later today, to see if it is different there.
Terribly slow for me two !
APP looks the same to me too.
Far too slow and clunky.
Use with the Core and it’s fine.
I went to the Webmedia on my Avant Mk1 and saw that an app is in the App Gallery - i think there are only 6 anyway
I had already used Deezer in the past on the Avant but stopped because it's so painfully slow.
On the BV14 what i had to do was uninstall the Deezer app that was pre installed as that didn't work, and then install the one in the Google Play store which works fine. Its not as slow as the Avant though.
Both TVs are direct lan cable
I never really use Deezer on either of these, and i mainly listen to deezer (music) on my A9 and BS1.  I have integrated an essence Mk2 with the BV14 on the chance i want to use the BV14 as an NL speaker with multiroom.
Yes, similar, core integrated to BV11 and just play straight from Deezer APP via AirPlay
I had forgotten about the deezer app on the V1, tried it on one of my V1s and it responded quickly to search and played music quickly. I have this hardware by cat7 cable to the router, so don't know if that made any difference.
I have a BS moment so always use that in the room
I have the same set up but Deezer on the V1 is sloooooooooow........
Maybe library size on Deezer ("My Music") is a factor? I have appts 1500 albums in there.
I only have 426 albums and 28 playlists, so maybe that is a fctor
