New Deezer App Beoplay V1 / BV 11
Finally the new Deezer app for the V1 / BV 11 has arrived and it seems to work flawless. Now hopefully B&O takes it up at their side to update the software so that the Deezer app can also be selected through the source button ( i.e. A-Mem button on beo4). For now this way the old buggy Deezer app is stil activated.
Does anyone on the forum knows if  B&O will keep updating the 1gen smart tv software? The BV11 is still on sale.
Yes bo aware and this is the last thing that needs doing
I can select Deezer with a source button on my V1.
Can someone tell me how I can access this new app from the BV11? On my Beo4 A.Mem launches the old (& still unreliable) Deezer app. I've checked the apps within the Smart TV section by cannot any Deezer app, am I missing something?
Any help appreciated, Matt
I did not use the installed Deezer on my V1 for a long time now - used the linked (from Essence) instead.
Inspired by this thread I tried to access Deezer, but it did not get past the first screen - no way to do anything there.
Has the app been updated, or what does the op mean by 'new Deezer app'?
Same inspiration, same screen effect
There is a Deezer app in the app gallery. I just added it to my home web media page on my V1.
I prefer the original Deezer application. The new app seems very slow.
Ok - got it.
Might be ok for a standalone tv.
But it can surely not replace the existing (well - de facto not-existing) app, since there is no way to use it as a source and to assign it to a button.
If you cannot do this, you can't access it from another NL device (apart from joining-in to perhaps?) or via converter on the ML.
It is exactly the same situation as we have in the new (Android-based)tv's, where apps can't be used as a source either.
I wonder how B&O is going to solve that problem there - - and I wonder if they are going to make the installed Deezer app on V1/BV11 etc working again.
C'mon Struer!!!
Thanks Razlaw, found it.
Matt
