Yes sent email to beocare and they are working on itOk - got it. Might be ok for a standalone tv. But it can surely not replace the existing (well - de facto not-existing) app, since there is no way to use it as a source and to assign it to a button. If you cannot do this, you can't access it from another NL device (apart from joining-in to perhaps?) or via converter on the ML. It is exactly the same situation as we have in the new (Android-based)tv's, where apps can't be used as a source either. I wonder how B&O is going to solve that problem there - - and I wonder if they are going to make the installed Deezer app on V1/BV11 etc working again. C'mon Struer!!! MM There is a tv - and there is a BV.
New Deezer App Beoplay V1 / BV 11
Thanks to all the well informed members on the forum I was looking out to this day, as I hoped the new software update should fix the Deezer bug and make the new app availablr through the source button (instead of the webmedia app launch). Unfortunately this was not the case.
Does anybody know what the software update fixed/added? Any ideas regarding the app fix? Would be so nice to use the multiroom / nl function on two V1's with the new Deezer app (old one is realy rubbish as it won't start up most of the times)
Coincidentally I did the same at the weekend with a new (old) BV11-55, and was too - pleasantly surprised - easily the best WebApp available on that OS.
Didn't realise you can map to a MyButton though ... even better ... thanks!
Tom
PS. Love the AJ Lamp - a classic!
You can also mapp the source to the MUSIC button directly.Coincidentally I did the same at the weekend with a new (old) BV11-55, and was too - pleasantly surprised - easily the best WebApp available on that OS. Didn't realise you can map to a MyButton though ... even better ... thanks! Tom PS. Love the AJ Lamp - a classic!
Thanks ๐I love it too ๐PS. Love the AJ Lamp - a classic!
That must have been a โsilent updateโ - I did not notice any.
Since when is it so?
Iโll have a look once I am at home.
Thanks ๐
I love it too ๐
I was noticing it, too. Very good taste.
Please do help me!
Just tested on my BV Avant.
I do see NO changes there from how it was before - it is just as buggy as ever....totally unusably.
What are you doing, that I am not?
Note: I have no Deezer account...if that should make any difference.
(Assigning a button is not a problem....never was.)
Register to access the forums, reference material, and exclusive member benefits โ including our monthly prize draw.
