New Catalogue is online now!
http://www.bang-olufsen.com/catalogue/
Iám 99% sure that all new picture is 3D render
Hmm dont now if I like it or not.....
Very nicely done - but I don't see the BeoVox 2 or the BeoSound 5 Encore - unless I need to delve more deeply?
Indeed, there's nothing about the new products, and the ones expected to be discontinued are still there (BS 3200 / BV6).
I find the online catalogue very good, there are links to other pages, audio and video clips, it's -finally- interactive, which makes it more interesting than the paper edition now..But I'll pick up a paper copy next time I visit a B&O shop! I've got them all since 1990.🙂
B&O must be nearly ready with the Encore as they have a web page (albeit with no real information in it)!
I got a copy of the new catalog from my french dealer yesterday and yes the Encore and Beovox are in it with picture and technical specs (also still BS9000, 3200, BS1, BV6).
Gregory
BeoGreg, would you be so kind to share a scanned copy of the pages with the Encore pictures and technical specs? That would be much appreciated.
Thanks, js
Js,
What I can tell right now (the catalog sits on an harmchair in my bedroom/i'm at my office) is that the Encore looks exactly like the Beosound 5 on the catalog picture.
On the tech specs you see that under the screen it's a little bit thicker and of course there is no more Beomaster 5.
You get access to 10.000 radio stations via Wi-Fi or Ethernet cable and you can hook a hard disk drive and a USB key or a computer.
Gregory
While we're talking "radio stations", does it tell if it supports podcast subscriptions?
Thank you Gregory, js
