New BS1/2018
The - Google - voice contolled BeoSound 1 seems to be avaiable now....at least in the UK.
ooh goody.  it will be here soon then.
Dumb question : for someone who will never use google thing, is the new BS1 any better than the "old" one ?
Any other difference appart from ok google ?
Maybe a different connector because it has a charging base like a kettle.
But that’s unconfirmed
I was told that it will get 4 quick access buttons.
These are the 4 dots/rings you see on the top.
When they will be activated, I don’t know.
The BS1/new has a charging base, yes.
Overall probably newer hardware inside - if (or when) we will notice that, is another question.
I suppose that we will see support for other voice controlled services as well - e.g. Alexa at some point.
My personal wish however, would be support for use with a BeoRemote One/BT - that would be helpfull.
By the way....
John o’ Manchester mentioned Spotify Connect in his presentation of the BS1.
However, Spotify Connect is not mentioned in the specs on the B&O website (it was for the original version).
So, who is right?
Millemissen wrote:
By the way....
So, who is right?
Email B&O support and ask. AAC wasn’t mentioned on the Beoplay H9 tech specs at launch but I emailed them and they confirmed (and as we all know now) that it was a supported codec and they updated the site 🙂
