New Beosound Core software ver. 2.0.47943
This just popped today in the app. Anybody installed it ?
Is there a change log somewhere ?
Cheers.
I installed it immediately my shapes core as I’m having playback issues. Can’t find any change log.
Is there ever a published changelog with B&O builds? Serious question
I’ve updated mine and my first impression is that Spotify Connect works a little smoother. Hi-speed surfing a track in the app seems faster than in 1.12. Although, previous versions, 1.10 and 1.11, were better.
I saw no new sound options added in the App. I like the “purist”, “hi-fi”,  feel of it:  just Bass and Treble :).
I haven’t had any playback issues tho.
If you are having playback issues, I suggest trying to wire your Core directly to your router using a CAT 6 cable that has metallic RJ45 plugs. See if it’s any different. If you can’t wire it, make sure you have good wifi signal to your Core. Go to “Setup Overview”->Your Beosound Core Name, and the wifi signal should be greater than -50dBm (eg -40dBm is better than -50dBm).
I also have a Beosound Stage, over WiFi, that was dropping multiroom playback together with the Core because it had -55dBm wifi signal. After a few re-arrangement, I managed to get the signal around -44dBm and now there’s no more multiroom playback drops from the Stage.
The only difference I've seen it that the Core now has a balance setting! ...or was that added in a previous update?
What I'm hoping for: less problems when having several access points with the same SSID. I currently have my Core cabled, but I'll give wi-fi a go again soon.
