New Beoplay app
Hi
If you don't have a Marker/Magazine then you can tap on the 'No' icon and you will be able to place BeoLab 90s. The scale will not be as accurate but hopefully it will give you a good idea what it will look like.
The feedback in your post has been really helpful and by the end of the week amendments in the app will help clarify some of the issues you were having.
- Simon
Sadly it doesn't work with the slightly older iPads as there is quite of processing power is needed to deliver a good performance. Looking down the line with future updates we needed to focus on the newer models.
- Simon
I glad you had a good initial experience, the developers have noted the issue and are trying to recreate the issue to find the bug. Thanks for the feedback.
- Simon
Does anyone know if the app communicates with the DSP in e.g the A2?
When I have adjusted the sound in my A2, using the app, the A2 stays with that sound setting even if the app is not activated next time I play from my iDevice.
The app has been updated for the A1 and also the H7 and H8.
However, there's still no support for the S3. Is the S3 the forgotten child of the Beoplay speaker range?
I take it back! There is now updated software for the S3 so it can work with the Beoplay app. I've just updated mine.
I just updated my H8s´s to the new firmware. They now sound different when switching ANC on and off. They make a "bliblipp" noise in both earphones at once. Before they seemed to enable on one earphone at a time and without the same noise.
The ANC can be enabled and disabled in the BeoPlay companion app as well - but its buggy so turning it off doesn't work, it just enables ANC when it is already enabled, but it states "off".
But the best thing of course is that you now can set the sound profile to your liking. There's been a lot of talk about H8 being too bass heavy (even though I think it changed in an earlier firmware - according to my ears). But now you can pick your favorite sound profile :D.
It's a very good update. The noise cancellation toggle works fine for me, though.
In the App? it works fine with the controls my headphones, but not in the app.
Yes, it works fine for me in the app.
