New Beoplay app
New Beoplay app at Apple Store!!
Only for iPhone - why?
I use my iPad Mini on the go for music with headphones.
Why not make it 'universal'?
Pretty cool app. You can select tone mode, volume etc etc
You must update A2 before you can use the app!
Ok - does it 'only' work with the bluetooth devices - and not with the headphones out?
Hahaha, for a second I thought there will be a similar functionality like a Mood Whell so I wanted to jump through the roof. But nonetheless, ok to get an update.
Not sure I will be using Beoplay app as I anyway need to stream from Deezer app so... ...well, someone is going to like it. :)
I updated my black BeoPlay A2 to the latest software version (9.2.7) with the BeoPlay Software Update tool on Windows 10. Then connected to the A2 with the new BeoPlay App.
The app itself does not bring very much in my opinion, but the very good news is that the whole process including updating works flawlessly and more important, you are now able to change the Bluetooth name of your device. So when you have more then one A2, you can now easily see to which A2 you are connecting. Also very convenient for shops I suppose, where I always have difficulty trying to connect to the right device.
Lucky you... With mine the updating process crashed immediately and after it the Beolit 15 refused to start again. No reaction. Dead. Even when plugged to the main, the charging led didn't react. It's back to the shop and I'll have a new one in some days under warranty.
I received right now a new replacement from the shop I bought it (not a BO store). I tried to download the update and.... exactly the same happend! DEAD!!!
I think I'm definitely out of B&O world....
Im curious to why this doesnt work with B&O play headphones. Although, I have to say its awesome to have this for the Beolit 15, I can't wait to try it out. Sometimes I find the BeoLit 15 too bass heavy, its not always a good thing :-).
Perhaps you should use another computer? It sounds like it cuts communication while flashing firmware or that you do something wrong.
