NEW BEOLINK APP.
Complet new  design of Beolink APP , Love it ...
Thank you very much!!!  This is something I've been waiting for a long time.
You can build new scenes/timers directly on the app .... This is great
How do you add timers? Does it work with MLGW or is the BLGW required?
I'm afraid it's only for Blgw
New future you can use the APP from Internet 4G,3G if you have a konto to khimo.com
Do you set the timer on the B&O products or on the BLGW? How is done on the app, screen shots?
The timer function sounds interesting. Do it work for ML-products or only NL-products? Yes a screenshot should have been really nice to see.
It worked before if you used VPN. I have Cisco firewall + built in VPN client in iOS and it works with MLGW.
Personally this is what I've been waiting for!!
It really makes the home automation users among us feel better with our blgw purchase!
Ties it all together nicely.
That looks really nice! Do you use the timers in any rooms, how do they works?
