New Beo 4 coming!!
"Completely agree. If you think you buy a Beo4 1710, enable "navigation button" in your BV7s remote menu, and now you can control all navigation- and enter functions with the the new (joystick)- center button, you are ..... wrong!".
I think thats because you have to update your puc/stb list...
Solvede the problem for me whith my Beovision 8 40Β΄ πŸ™‚
Shaun
Ok. Thanks for the hint. I`ll ask my dealer....
Is it possible to navigate with an "old" Beo4 when it is set to "navigation button" - especially from linkrooms?
Stefan
Yes it isπŸ™‚
But with out the navi control of course..πŸ€’
I am verry happy with the new beo4, makes the use of my tv and viasat hd/panasonic bd much betterGift
shaun
Thanks. I think I will also be happy with my new Beo4 soon....and maybe Roger to.....πŸ™‚
Stefan
Stefan
I am glad for you My dealer was unable to convince me with his demonstration
mr_anders_son wrote:
both display and buttons is illuminated...and yes I love mine;)
??? Are you talking about the Beo4 1710 ???
Stefan
B&Ola wrote:
@Keith: How do you set the new Beo4 to a reduced Ir-transmission? I can't find that in the menu. /Ola
The Beo4 Infrared transmitted power can be changed to one of seven (7) levels. Level 1 is the lowest IR power level and 7 is the highest.
To change the the infrared power level you must go into the Beo4's Service Menu by doing the following:-
  • Press STANDBY and LIST at the same time, then press MENU and GO button at the same time.
Press the LIST button several times until you see IRPWR : X is shown in the display where X will be 4 unless its been changed,
