Here is a translation of a Danish thread showing a new version of the Beo4.
It seems to have a track ball, like on the Blackberry's pearl.
p.
p.
As far as I was aware, it was already here, I mean the new Type 1710 version which is very much aimed for use with the Masterlink Gateway.
And no-one told me ;-)
Do you know in what way will it work better with the MLGW?
As it got the track ball like the one in the link above?
Noting that it retained the LIST button and assuming it is a track ball... perhaps the ball allows more fluid scrolling through the list(s)?
I cant stand the track balls on Blackberries. Which is why I bought the Samsung Epix i907....
Go optical B&O!
How true!!!!!!! But I heard a rumor about a Beo6. Can anyone confirm this?I cant stand the track balls on Blackberries. Which is why I bought the Samsung Epix i907....
Go optical B&O!
How true!!!!!!!I cant stand the track balls on Blackberries. Which is why I bought the Samsung Epix i907....
Go optical B&O!
Seriously though, lets not screw it up by putting moving pieces on a remote (I realize the Beo5 has a scrolling wheel). Every moving part can become an unnecessary potential failure point.
Biggest advantage will be easier use of set top boxes - simple "UP" / "DOWN" to change programs
(instead of "GO" + "UP" on recent BEO4's) using the little "Joystick" to navigate in menues.
Dear Gang,
Do you see anything in this new remote's button design to indicate that the new Beo 4 will operate more logically with stuff like the BV-7's Blu-Ray player - i.e. do you think things like skipping to the next chapter on a disc will involve one press of a button like on the Beo 5 remote as opposed to the series of button presses required on the current Beo 4?
Mark
The new Type 1710 Beo4 looks almost like the previous version, but in practice the main PCB and keypad have been changed.
With the new version you now have three (3) modes of operation which you set the Beo4 too depending on your configuration. which to a certain extent is in principle similar to the previous Audio & Video settings.
When you go to ADD items to the LIST you will now have three options being AV, LIGHT and CONTROL
Like the Beo5, we also have ZONES as below:-
One area which I am sure is going to cause all sorts of confusion is the fact that a Beovision TV has to be "Beo4 Type 1710" compatible and you will know if your TV is compatible if it has a "Beo4 Menu". If it is not, there's no problem because one of the three "MODES" effectively makes it the same as previous versions of the Beo4. In my view this is going to be a major issue for dealers who have an existing customers who purchases a Type 1710 Beo4, but then the dealer finds he also has to update the software in the TV's to make it compatible or set the new Beo4 to MODE 3
In TV's which have a "Beo4 Menu" meaning they are Beo4 (1710) compatible you can select "Navigation Button’"or "No Navigation Button". You should only select the "Navigation Button" option if you have a Beo4 (1710) If previous version Beo4 is used when "Navigation Button" is selected in the Beo4 setting menu on the TV then:-
The three MODES are:-
When this version of the Beo4 is used where certain PUC control devices are used, then the PUC may need to be updated. This is because some "Function Codes" with HEX addresses 1B and 1C have been assigned for Masterlink Gateway commands.
Interestingly, you are able to change the IR transmittered power level which will certainly please a lot of B&O dealers. Apparently the power level can be changed to 7 different levels.
