New Beo 4 coming!!
hmm strange because BV9 is based om Beosystem 3!!??
Same as BV7...
mr_anders_son wrote:
hmm strange because BV9 is based om Beosystem 3!!?? Same as BV7...
Indeed!
Since the arrival of the 7-55 the BV 9-50 is certainly not a top priority
product on their to-do list anymore ...
Vienna wrote:
Rolf wrote:
Anders Did you get any answer / solution to the issue of the missing Menu option.
I also have a BV9 newly updated s/w 8.12a but no Beo4 option.
Simple Answer - BeoVision 9 is not (yet ?) on the list of "Compatible Products"
Products / SW versions beeing "Beo 4 Navigation Ready"
BeoVision 4 - Build 632
BeoVision 7-40 MK III - Build 632
BeoVision 7-40 MK IV - Build 632
BeoCenter 6-23 - 10.05a
BeoCenter 6-26 - 10.05a
BeoVision 6-26 MK IV - 10.05a
BeoVision 7-32 MK V - 10.05a
BeoVision 8-40 - Build 109b
BeoVision 10-40 - Build 109b
BeoVision 10-46 - Build 109b
The 7-55 is not compatible?  Do not see it in the list?
The 7-55 is compatible, the list is not complete...... My 7-55 was deliverd last week and it has the ability to chose the Beo 4 with or without navigation button. So I can confirm the compatibility.
By the way, the 7-55 is awesome, I really enjoy the Worldchampionship soccer, so much dept and a razorsharp image in HD! No motion blurr at the ball (at least I can't notice it!) Now let's hope "we" will defeat Brasil next Friday!!!!
Regards,
Rob
Curious - the 7-55 is not on the list ...
My  7-55 has the "Beo4 option setting" in it's menue
and I operate it with my Beo4 1710
(set to Mode 1 = Navigation button enabled))
@Keith: How do you set the new Beo4 to a reduced Ir-transmission? I can't find that in the menu. /Ola
It seems that I must change some hardware in my BV9:-/
You must have at least IOP 23.00, I have 22.00.
And this is not a software issue...
I am waiting for price info....sucks
Do you remember when the Beo5 was launched and a simpler remote was in the pipeline, and the Beo4 was set to die by the end of that year? Now they have launched a new version of the Beo4... The old BeoLink 5000 design must be good (not saying that the simpler remote was killed, it could surface within the next few months with the launch of new music system).
The Beo4 1710 is perhaps the most confusing B&O product I have every owned. The Beo5 takes some effort, but after living with the new Beo4 I have re-programmed my two Beo5´s. Why? It is easy to answer - let me start with the positive remarks: operating the built-in DVD player in the BV7 with the Beo4 1710 or the Beo5 is straight forward and logical, which is very good news - and I use the LIST button a lot, so moving it to a more thumb-friendly-location is also good news.
So what is the downside? Operating my STB is very frustrating. You still have to use the same "GO" + "#", but now the GO-button isn´t the center button - but the play button next to stby button. This is not a thumb-friendly-location, so to have the best of both worlds there is only one solution: Beo5.
Or am I missing something with respect to PUC/STB-C operation? And as Keith said: you can set the IR power to different levels, someone within B&O told me that (at max transmission power) the new Beo4 is 10x more powerful than the previous Beo4.
Roger
Completely agree. If you think you buy a Beo4 1710, enable "navigation button" in your BV7s remote menu, and now you can control all navigation- and enter functions with the the new (joystick)- center button, you are ..... wrong!
I can control the BV7s DVD player and the new DVB/S HD modul this way, but when I switch to my external stb or my BD player I have to use the PLAY buton instead of center button and up/down - L/R buttons instead of the stick....(?!) When I try to navigate in the DVB HD channel list in a BC6-26 linkroom using an "old" Beo4 it just doesn`t work. It refuses to scroll using the up/down buttons! I played around with the differnet modes - navigation/no navigation - and MODE 1 - 2 - 3 on the new Beo4, but no luck. Finally I disabled "navigation button" in the BV7 menu (I can now control the DVB HD modul and the DVD player from linkrooms with old Beo4s) and set Beo to MODE 1 (I can now use the navigation button in the main room for the DVB HD modul and the DVD player)
Also agree. Let me add you can scroll forward and backwards through the LIST with the navigation button which makes it more comfortable, especially if you have a lot of buttons in your list. Another improvement are the new LIGHT- and CONTROL functions like LIGHT MORNING; LIGHT TV VIEW, LIGHT SLEEP....I set some nice macros to my Lintronic box using these buttons.
I`m afraid not.
Roger
How can I do that?
Stefan
You would hope that the PUCs will be updated to become Beo4 1710 friendly.  Suppose we have to wait and see.
