New Beo 4 coming!!
BeoNut1 wrote:
Now I just wish there were a way to have the "TV" button turn on the cable box in addition to the TV, but I guess the "macros" will be solely relegated to the Beo 5.
An interesting alternative for older TVs without possibility to assign "TV" to other sources
is the Beo 4 "for the Digital Age" - recently made in small quantities to check market response!
"Beo4-DTV", B&O Item 8053529, (That's NOT the NEW BEO 4 Type 1710) offering:
"DTV" "V.Aux" "V.Mem" instead of
"TV" "DTV" "V.Mem" as buttons of the left column.
Everything is the same as on a "normal" Beo 4 type 162x, exept "V.Aux" converted to a "real"
button and "TV" changed to a softkey.
Please note: not yet clear if the diverging parts (mainboard, rubber) for this model will
be available in future as a sparepart or you'll have to buy a new one again.
But, at least display and metal casing are looking like beeing standard types.
Thanks for sharing Mr. Anderson. What's it like to use?
Its not mine its from B&O site;-)
But I shall order one tomorrow....ofcourse;)
TWG, they did at one point that's what differentiated the Beo4 from the Beo4 Cinema edition, other then it having a button labeled Cinema!   I recall the Cinema edition having some/if not all illuminated keys, not sure about the backlight display though, but I believe it did.   From my understanding they are/were a rarity though!
both display and buttons is illuminated...and yes I love mine;)
Nice, in "Mode 2",  like a "Standard Beo4"
even nicer in "Mode 1"  (when the TV has the option "Navigation Button")
mr anders son what was the type # on the Beo4 Cinema?
mr_anders_son wrote:
csmager wrote:
Lots of info!
It's not totally clear - can you have a 1710 in the main room with a TV that supports Navigation Button (e.g. BV7 with Software 8.12a)
where can you see this in the menu? I have BV9 with 8.12a
Anders
Did you get any answer / solution to the issue of the missing Menu option. I also have a BV9 newly updated s/w 8.12a but no Beo4 option.
//Rolf
Rolf wrote:
Anders Did you get any answer / solution to the issue of the missing Menu option.
Simple Answer - BeoVision 9 is not (yet ?) on the list of "Compatible Products"
Products / SW versions beeing "Beo 4 Navigation Ready"
BeoVision 4 - Build 632
BeoVision 7-40 MK III - Build 632
BeoVision 7-40 MK IV - Build 632
BeoCenter 6-23 - 10.05a
BeoCenter 6-26 - 10.05a
BeoVision 6-26 MK IV - 10.05a
BeoVision 7-32 MK V - 10.05a
BeoVision 8-40 - Build 109b
BeoVision 10-40 - Build 109b
BeoVision 10-46 - Build 109b
