New B&O floor stand for Stage
I'm actually surprised STB Brackets didn't get the 'Gig'....
ok it does not blow me out of the water but I doubt if any (fixed) stand can do that ;-).
I like the fact that it is black and I think with a 48 inch screen the whole package would look very good as the stage is than nearly the same size of the tv, which looks better imo than with a 55 or a 65 inch panel.
It is simple but also a bit boring.
I dont think this is a bad idea at all.
Of course its not mind blowing design wise, but its coherent and more so than any other  hacky solution.
And as part of a package offered by B&O with stand, tv, speaker and remote, it makes sense.
Not for me, but given the relatively low investment this has probably required, it may help further with selling the Stage, and dealers in general.
I agree, but we also need to remember the design of the GX was supposed to be absolutely flush against the wall. The wall bracket is designed to sit inside the back of the TV. Unless this is only for the CX as it says on the B&O website 'for the C-series'?
I'm really happy with my 65" GX. Looks neater than the huge BV12-65. Indeed, in hindsight I could have gone for the GX 77" as the wall is certainly big enough!
The STB Brackets mounts support both C9 and CX so I assume they have almost identical backsides. I believe the E9 and GX could also be used because they have very similar mounting positions, just a lot thinner. I feel like B&O should provide a list of TVs that work with this stand, that would make the buying decision a lot easier. Just marketing to LG OLEDs seems pretty limited.
Just noticed STB has added a "Pull & Rotate" wall mount for the GX and Stage that looks pretty nice and compact.
If i was designing a future update of the stand and there was a way to make it motorised, I would also make the bracket motorised to operate vertically as well as horizontally to fire the atmos drivers up to the ceiling
After all it is designed to be operated in both scenarios
Really cool. I only miss powerlink and puc. If there was a stage with that then I would be all good. I am seriously considering selling all my Beolab 20/8000 etc because it’s so hard to move to a future solution as of today.
The eclipse is getting dated and the speaker is too wide. The harmony is overpriced and hasn’t got a moving stand and a LG screen is cheap and great on it’s own.
With a speaker as the stage a simple and discrete installation can be fulfilled and if only it was also possible to use it for surround sound and stereo speakers it would be worth a few thousands more.
The stand looks awesome and seems a way towards a future with more choices, hopefully!!
It's cool. Like it! And proper cable management it seems.
Karel.
