Hello everybody,
After a longtime passive user of this forum and B&O adapt (my parents use it since 1986); my wife and I are finally in the market for a full B&O home installation. Nevertheless I would like your advice on some things.
I will start with my "needs/habits":
- I would like a simple, hasslefree, foolproof system with extra's such as a timerfunction and roomlink capabilities.
- In total I have about 250 cd and I'm using I-tunes (& ipods) since a couple of years and buying my music online.
- Most of the time I listen to the radio or recently bought I-tunes songs and CD's.
- The Main room is a closed 5m by 10m (part living and dinning room) (see plan as attachment)
- Main room TV: the Beovision 10 (not the BV 7 40 which was on my first quote, reason: cheaper and I will never use the Beosystem 3 options)
- Question 1: What do I hook up as audio system ?
- the beosound 4 (or Beosound 3200)?
- includes timerfunction
- apparently capable of listening to different sources in different linkrooms (is this confirmed ???)
- nevertheless pretty
- simple radio, cd (and Memcard function)
- capable of connecting to Beomaster 5 (operated either through the BV10 or on the BS4, right ?)
- and still works perfectly when BM5 would it decide to breakdown or freeze up, or when the internetconnection is lost
- No MOTS
- Can I connect a BS5 to this as well?
- Beomaster 5 + Beosound 5
- timerfunction ??? Not available or maybe through an software update ? Or just use Beotimes?
- hasslefree ???
- eye-catching
- MOTS
- Question 2: My current idea is to go for the BS5 (and BM5) with the option adding a BS 4 or BS3200 in the future. I guess than mainly because of it esthetics or does it have extra possibilities). How would or can both work together in a ML systeem and which to make the master with what consequenses?
- Question 3: What Loudspeakers connected ?
- Beolab 4000 (4 times to create surroundset up)
- I like the design very much as they are unobtrusive and pretty
- ICE power - but enough ??
- linked with a Beolab 2 for bass
- cheaper
- Beolab 3 (4 times)
- I would assume enough ICE power
- less unobtrusive
- plus the Beolab 2 ?
- more expensive , worth it ?
In the linkrooms I would have mainly BV8's or BV6's (Kitchen, study, masterbedroom) and a BL3500 (bathroom).
The HD content would be coming from a separate Kathrein SAT-receiver with 500GB HDD, a TVIX and a Blurayplayer
Please advice , any input is most welcome !
Seasons greetings and happy 2010.
