hotknife wrote:
I can not find any mention of 3D??? But should be the latest version, arriving soon, because "old" panel has had
Cold Cathode Fluorescent Lamp (CCFL) as BACKLIGHT TYPE.
I had to double-check this: 3D is mentioned ONLY in the specs for the 55" version, and 3D is also mentioned in the product description of that model elsewhere in the catalogue. There is no mention of 3D in the specs or description for the 40" model -- none whatsoever. So is the 40" model undergoing another panel change soon? Now first CCFL to edgeLED panel, and later to a 3D panel? It would be rather peculiar to have 2 new Mk's of 7-40" in a short period of time... It would mean that if you buy one now, you get the edgeLED version, but no 3D, but a little later you might also get 3D.
To my recollection, didn't B&O state that they consider 55" to be the minimum size for a screen to really benefit from 3D? I could remember this inaccurately, but it would go towards explaining why the next Mk of 7-40" is not 3D, even though it has undergone (or is undergoing) the panel change mentioned in the new catalogue.
Perhaps the new panel is 3D-ready already, but the feature -- which requires active shutter glasses with the 55" model and therefore the sync signal transmission component built-in the set -- is not enabled with the 40" model.
I guess those wanting 7-40" with 3D will have to wait for the official word and clarification from B&O...
