New 7-40 - any word?
From previous threads i was expecting a new 7-40 to have been released already. Anyone have any news and whether it would be full LED like the 7-55?
It`s the 3D-Version. But isn`t also the new 7-55 "only" direct LED backlit with screen type 55" 16:9 TFT LCD, glare surface???
For the specs of BV7 - 40", the new catalogue states that the panel has been updated. It is now an edge-lit LED LCD, with LEDs on two edges of the panel. The total number of edge-LEDs is stated to be 144. So it does not have the direct LED backlight as the 55" model has. My guess is that it uses the same edge-LED panel as the recent BV10 models do.
I Am feeling quite disappointed that the BV7-40 has not the same picture technology as the BV7-55. What is the reason for me to buy this and not the cheaper BV10? I know it is the BS3 inbuilt. The 7-55 is still the best LCD ever seen and the little brother should be as good as it, just smaller..
But I also thought the new BV7-40 3D would be a 16:9 TFT LCD direct type LED backlight, local dimming divided into zones, scanning backlight??? Or will B&O realise the 3D technologie with its old 40" 16:9 TFT LCD, glare surface cold cathode fluorescent lamp (CCFL)?
I`m confused🤔
I am afraid that I don't know the answer to this question.
I do know, that B&O will select what they feel is the most appropriate panel currently available for the 3d BV7-40.
Surely at that point you go to your dealer and have a look at the picture quality, and hopefully you will agree with the engineers that the picture will be fantastic.  If it is, and you can justify the cost then you buy it.  If not, then you don't.
Any screen fitted will be chosen for it's viewing properties, not a specific technology that is or isn't used, and of course will meet all requirements for power consumption etc.  I honestly can't think of a single reason why a buyer would care whether it's local or edge dimming, or even CCFL as long as the picture is as good as it can be based what is currently available.
I'm quite sure the BV 7-40 will get a new panel. But the question is if Samsung has a 40 inch panel available with the technologie of the BV 7 55 inch panel. If not, B&O will use the best 40 inch panel from Samsung (I hope so).
/Räuber
That is unfortunate as I was hoping for the backlit LED technology, as from what I have seen from other vendors it is superior to LED edge lit. I did see the 7-55, and while it looked wonderful, it is far too large and dominates the room in my opinion.
My understanding is that there is no change to the panel except the addition of the 3d function when I spoke to the dealer
Vince
My dealer told me a few weeks ago that the BV 7-40 3D will get a new panel but he didn't know the specs.
But KMA had seen the specs in the new catalogue, so let us believe these specs are true.
I have not the new catalogue but B&O should update their website with the specs of BV 7-40 3D very soon.
I also hope they use the panel type that offers the best possible picture quality on a 40 inch tv, because the BV 7-40 is not the cheapest tv on the market!
Regards
Räuber
