Network delay suddenly happening? B&O App?
And restarting the wifi router did not help either?
NopeAnd restarting the wifi router did not help either? MM There is a tv - and there is a BV.
I know it sounds weird but try to unplug every BO multiroom product from mains, wait 60 seconds then plug them all back.
I noticed the same issue with my BeoSound Core. When it happens, the music starts with a “fade-in” effect for the first 3 seconds.
If I play a 24/192 flac over local DLNA, the delay is even bigger, around 5-7 seconds.
Neither rebooting the BS Core, the router or DLNA server works to solve the delay.
Only unplugging the Core from the mains solves the issue for me.
In my case, I think the delay happens after I (rarely) change the Bass/Treble sliders in the BO App.
Cheers!
Glad to read this, I noticed this behavior too following the latest Core software update, and I like it to be honest. Another new hidden feature.
I raised it in this forum but had nobody confirming.
I missed your forum post about this. Indeed, I first noticed the problem a few months ago, coinciding with the last Core software update.
I don't think it's a hidden feature :). Most probably a bug.
A nice bug then IMHO as often volume levels are not the same across sources, fade in when changing a source makes the transition smoother.
This is something I would like on other products, as an option for example, particularly on my BS1 which wakes me up every morning with a radio channel, fade-in would make a smoother awakening !
I tried playing around with the network delay to test and the settings are as they always are
What value do you currently have for WiFi delay?
I had similar issues, smaller sync delay though, between my M3 and my Moment and the only way I managed to recover temporarily was to change the WiFi delay to force resync between products.
Do you have a WiFi mesh network?
