NeoPDP, BV4 and BeoSystem 3
As far as I know the Beovision 4 is not a NeoPDP panel, but are there any plans to update the BV4 line with NeoPDP displays.
I am thinking of buying the Panasonic TH50PF20 which is a NeoPDP panel but I am unsure what my BeoSystem 3 would say to that. Since the BV4 uses the TH50PF10 and 11 panels I would hope the PF20 would be compatible with the BS3 - however it is the first to be based on NeoPDP technology. Any thoughts on the combo?
Bump bump .. no takers on this?
I am trying to get the TH-50PF20 working with my Beosystem 2. Now I have the same issue as you had concerning the RS232 cable. Which exact version did you use successfully?
Many thanks and
BR
I dont have a TH-50PF20 and was only wondering how it would work with my BeoSystem 3. I did have a PF11 but I never got the setup working with the RS232 before the TV broke (accident), and I have not bought the PF20 yet. I want to buy the PF20 but being NeoPDP and the fact that BS3 software being very special - maybe it wont be a good match. The BS3 makes the pictures worse on a lot of flatscreens other than the panasonic panels used inside the BV4.
But it looks like that no one on beoworld knows about the future of the B&O plasma panels and if NeoPDP and BS3 works together.
