Needs help to connect Beosound Ouverture & Beolab 3500.
hello all
I’m new in this forum, I love B&O appareil, so I’ve buyed some used one (beovision Avant, bs ouverture, beolab 3500 & some beocom ) to try, gradually, to make a nice integrated system.
Now I have a problem with my BeoLab 3500 & my Ouverture.
Let's see if I can explain the problem with my bad English.
I have my Ouverture connected to my BeoLab 3500 with a Masterlink cable and the result is ...disappointing.
I’m using the beo 4 remote to control “the system” but…I cannot control anything.
I’ve finished to connect cables and I’ve turn on the system, the clock time appears on the display of BeoLab, but via beo 4 it’s impossible to turn on the music, the overture respond to commands...but not transmit music to the BeoLab.
Magically, pressing the physical button to the right on the BeoLab  3500 the radio turn on & the music came out from the speaker but…trying to using again beo 4: the overture it’s able to change the music source (radio, cd tape) but does not allow changing the volume, turning off the overture from the remote control the clock reappears on BeoLab.
I tried different settings (A.opt & L.opt)... but I have not accomplished anything.
anyone have any suggestions for me?
Thanks in advance and sorry again for my bad English
John
Hi John and welcome to the forum!
  Is the Avant also connected to the set up via ML?
  Are the OT and 3500 in the same room?
Jonnie
Look for option settings: ouverture option 0, beolab 3500 option 4 (not sure).
Search the forum for how to set options with your remote.
Found this thread!
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
Sorry, I assumed only ouverture and bl 3500 are in the room connected.
Option 0 turns of the ir reciever of the ouverture.
Option ? turns on the one of the bl 3500....
Ralf
The Avant is in the same room whit the ouverture and 3500 but just 3500 & Ouverture are connected via ML.
Giovanni
I've tried the setting described in this thread whit no result.
Set the whole system to standby.
If all products are in the same room set:
Ouverture: A.OPT 0
Avant: V.OPT 1
BL3500: L.OPT 5
The concerning LEDs should flash shorty when you set the options.
Hope this helps.
Stefan
Tried settings described in Stefan post...not work  LEDs flashed shorty in Avant & ouverture but not in beolab.
...!no result|
I have to go to the dealer b&o?
p.s.: No dealer in my city! just 1 in all my region.
Hello,
If I understood your installation correctly:
Avant and Ouverture in one room and NOT connected by Masterlink
BL 3500 in another room ML connected to Overture
The Option setting should be:
Avant: V_OPT 1
Ouverture: A_OPT 1
BL 3500: L_OPT 5 or 6
Do You have speakers connected to your Ouverture. If not, it could be that the Ouverture defaults to A_Opt 0
In this case you should to ML it to the Avant:
Avant: V_Opt: 2
Ouverture: A_Opt: 0
BL 3500: L_Opt 6
hfat
Hi, before trying link settings etc, did you make the masterlink cable yourself? If so it's very easy for one of the cables to not make a clean connection causing all kinds of issues.
Can you try a different masterlink cable? This will ensure that the connection between the two units is not at fault.
Regards,
Cal
