Need help: install glass on Beosound 4
Normal 0 false false false EN-US X-NONE X-NONE MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin-top:0in; mso-para-margin-right:0in; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
hi there,
One of my friends bought a used Beosound 4 and it come with the glass separately. I would like to help him to install the glass but I do not have any idea and I.ve just downloaded the manual from B&O but not mention how to do it.
Any help will be highly appreciated.
Just line up the clips on the glass, to the brackets in the sliders on the BS4,
VERY easy job, it just clips on.
Try pg. 23.
many thanks for the info!
