Near miss with beovox P30s
Hi all, had a pair of beovox p30s brought over from the uk, sound really good after testing for a few days so decided to put them on the wall
very diligently measured up and drilled holes, happy with the level so decided to offer them up to hang on suitable screws
all good so far, looking very nice indeed, stepped back to admire and the speaker popped off the wall, luckily i was there to catch it, gave me a bit of a scare though
on examination the two plastic brackets I was looping over the screws just popped out and were hanging there on there own on the wall
cant see any evidence of glue that has degraded but presume something kept the little bracket in place on the speaker, will I be okay to just superglue or something similar to fix the problem
any thoughts anybody, thanks for any replies
Adjustable plastic disks with a very high pull-out load because of the angled resin back?
I'd think about abandoning them and trying picture frame hanger loops screwed to the back with self tapping screws.
Graham
You could be right, will see what I can find locally, cheers
