Dyssegaard
Nice tip!
Is that a 46" or 55" you have there?
Does it matter for the space available?
It’s a 40” so I guess that there won’t be less space in the bigger models.The ATV4/4K has a depth of 35 mm, so it should be easy to verify in advance if it will work.Nice tip! Is that a 46" or 55" you have there? Does it matter for the space available? Livingroom: BL3, BL11, BV11-46 Kitchen : Beosound 1 GVA, Beocom 2 Bathroom : M3 Library : A6, Beocom 6000 Bedroom : M5 Office : Beocom 2 Travel : Beoplay E8 2.0, Beoplay P2
You win at living rooms 🙂
Thanks 🙂You win at living rooms
Very nice 😁PS: My answer rgd. size (my BV11 is 40 inch) seems to have been blocked by the moderator. I don’t know why🙁.Got inspired and did the same on my BV11-46. Worked very well: Now the cabinet under the TV is empty Livingroom: BL3, BL11, BV11-46 Kitchen : Beosound 1 GVA, Beocom 2 Bathroom : M3 Library : A6, Beocom 6000 Bedroom : M5 Office : Beocom 2 Travel : Beoplay E8 2.0, Beoplay P2
Cool!
What is the piece made of? Plastic?; Hence you can easely take it off?
Yep, plasticCool! What is the piece made of? Plastic?; Hence you can easely take it off?
