My dealer showed me how to mount an ATV4/4K inside a BV11
For some time I’ve had an ATV3 mounted inside my BV11 (my wife doesn’t like external boxes). Login to view imageI would like to have an ATV4K instead, but there wasn’t enough space for it (it’s 12 mm thicker than the ATV3), so I asked my local B&O dealer what to do. He showed me, that the BV11 was actually preparred for it, but it required that a small piece of the inside cabinet was removed. Before removal: Login to view imageAfter removal: Login to view imageThis piece was removed: Login to view imageAnd now the ATV4K fits nicely: Login to view imagePS: The PUC table for the ATV4K is great. It has direct access to Home screen and Airplay speakers 😁
Best regards
Dyssegaard
I agree with your wife that external boxes are ghastly. Good job. Thank you for sharing. I’ve wanted a Bv11 for years but my wife has gone the Costco route sadly. The ability to hide boxes away is a strength with this TV.
Nice tip!
Is that a 46" or 55" you have there?
Does it matter for the space available?
It’s a 40” so I guess that there won’t be less space in the bigger models.The ATV4/4K has a depth of 35 mm, so it should be easy to verify in advance if it will work.Nice tip! Is that a 46" or 55" you have there? Does it matter for the space available? Livingroom: BL3, BL11, BV11-46 Kitchen : Beosound 1 GVA, Beocom 2 Bathroom : M3 Library : A6, Beocom 6000 Bedroom : M5 Office : Beocom 2 Travel : Beoplay E8 2.0, Beoplay P2
Best regards
Dyssegaard
Got inspired and did the same on my BV11-46.Worked very well: Login to view image Login to view imageNow the cabinet under the TV is empty 🙂 Login to view image
You win at living rooms 🙂
Thanks 🙂You win at living rooms
Very nice 😁PS: My answer rgd. size (my BV11 is 40 inch) seems to have been blocked by the moderator. I don’t know why🙁.Got inspired and did the same on my BV11-46. Worked very well: Now the cabinet under the TV is empty Livingroom: BL3, BL11, BV11-46 Kitchen : Beosound 1 GVA, Beocom 2 Bathroom : M3 Library : A6, Beocom 6000 Bedroom : M5 Office : Beocom 2 Travel : Beoplay E8 2.0, Beoplay P2
Best regards
Dyssegaard
Cool!
What is the piece made of? Plastic?; Hence you can easely take it off?
Yep, plasticCool! What is the piece made of? Plastic?; Hence you can easely take it off?
