MX7000 Stand Issue
Guys I have a problem with my stand, which very stupidly was caused by me! I have just recently brought an MX7000 with a motorised stand, it worked great and I was very happy with the picture and the sound was good to! But I had to move the telly, but I forgot unplug the stand, so I think you can guess what happened! The plug stayed in the Tv and the wire was ripped from the plug. Now I know this is repairable its just a simple case of solering back on the wires, but my dillema is that they are coloured and I don't know which wire goes on which pin in the plug. There is four pins that I need to correctly solder, otherwise it just will not work properly. So guys my question is what wire goes to which pin? Thanks in advance for any advice guys.
Nidul
Take a look
Exeter,
Devon,
UK
Hi Stoobie
That diagram did help a little, but what I really need to know is what colour relates to each pin. From that diagram I can see that the pins are numbered and what each wire does but not where they go. So if anybody else can help it would be greatly apprieceiated.
Nidul
Anybody out there who can help?
solder side of plug up, pin arc to top yellow, brown, white, blank ie left to right
Tony
