Guys I have a problem with my stand, which very stupidly was caused by me! I have just recently brought an MX7000 with a motorised stand, it worked great and I was very happy with the picture and the sound was good to! But I had to move the telly, but I forgot unplug the stand, so I think you can guess what happened! The plug stayed in the Tv and the wire was ripped from the plug. Now I know this is repairable its just a simple case of solering back on the wires, but my dillema is that they are coloured and I don't know which wire goes on which pin in the plug. There is four pins that I need to correctly solder, otherwise it just will not work properly. So guys my question is what wire goes to which pin? Thanks in advance for any advice guys.
Nidul
