hi i have an mx4002 and i have a small problem as it keeps switching itself on! it could be within ten mins of turning it off or could be a few hours later?
can anyone help?
(my mx4000 doesnt do it!)
cheers
mark
can anyone help?
cheers
mark
Hi Mark
Di you have it connected to a main TV somewhere else in the house?
Is it posible that you have avtivated the timer function?
Have you got a set top box connected directly to it?
Regards
Opman
the only thing connected is a virgin media box no other connections?
thanks
Some years ago I heard of someone with a 21" MX television that had, I think Sky connected. He never used the aerial feed only the digital box. He suffered similar problem of the set intermitently switching to stand by. After much investigation, the problem was resolved with a software update on the tv.
Do you have an aerial feed that would enable you to temporarily disconnect the Virgin box to see if the problem persists?
Opman
yes i will try the aerial feed for a few days and see how it goes.
cheers
mark
If Keith sees this thread I hope I've asked the correc t questions to help you identify the possible problem π
Opman
I had this problem with a "threeview" box.It was noise from the box intermittantly sending a "play" signal to the tv via the Scart cable.
Use a good quality Scart cable anyway.You may need to ground the aerial cable if you are using a "booster" rf amplifier.
Scientific Atlanta cable tv boxes are haunted in my experience,if you have one of these,suspect it!The later Samsung boxes seem better?
Regards,
Nick
my wife thought we had spooks π
yes i have the new samsung box with a good scart lead
hats of to keith he is the man and has been a great help in the pastβ
had a similar problem with a panasonic sky box onto a 4002 eventually resolved it by going into box services - system setup and picture section in there switched off scart control switch - i have no card fitted so have to use the sky remote to control satellite reception - in france, with the set working on terrestrial french tv and satellite for english program reception
the above solved my phantom operation (usually 2 or 3am and a bit of a pain!)
cheers
tony
Hi a11mcr,
we had the same problem in germany with a "premiere box ", my husband cut off
the pin 8 connector on the scart scable and all problems are solved. The Box switches on between 3 and 4 o' clock am and the mx switched on.
see wikipedia for the pins off the scart cable
hope this will help you
SERENE
Register to access the forums, reference material, and exclusive member benefits β including our monthly prize draw.
