I've been trying to use MasterLink for the first time, and seem to be *almost* there. My problem is incorrect aspect ratio when displaying widescreen data from the Avant on the MX4002.
The Video Master is an Avant RF VCR, with DVD1 attached to the AV port, and a Humax 9200 Digital Terrestrial box (DTV) attached to the Decoder port (and STB-C). All aspect ratios seem OK (i.e., DVD and SAT give widescreen image)
The MX4002 has no external devices, and is connected direct to the Avant by a MasterLink cable and a UHF lead.
From the MX4002, using a Beo4 contol, I can select LINK-TV, SAT, V.TAPE or DVD from the Avant. DVD and SAT give tall skinny images. LINK-TV and V.TAPE images look OK, since they are fullscreen data displayed on a fullscreen TV.
The problem is that the Letterbox image from DVD and SAT is not converted to display correctly on a 4x3 screen of the MX4002.
Can anyone tell me what should happen here? Is the Avant supposed to create a Zoomed image from the 16x9 images for transmission to the MX4002, or is the MX4002 supposed to switch to Letterbox mode, so giving black bars at top and bottom? How do I make it happen? The FORMAT option on the Beo4 seems to have no effect on the MX4002.
Any ideas?
Mark
