MX4000 Questions
Hi all,
a couple of new questions if you can be kind enough to post with any answers
1) MX4000 with motorised stand and Beo 4 remote - I have the AV programmed in the menu as non B&O VCR to watch Sky in my bedroom - that is the only connection I use - I turn the TV on using the Vtape button to view Sky - however to access the Stand I have switch back to TV (channel 1 for example which obviously has no picture being transmitted) otherwise the stand icon does not appear and I cannot control the move it - anyone know of a workaround - I would like to be able to access the stand function at any time and not have to switch back - basically I want to show off to family and friends and the process of switching back and forth spoils it a bit
 2) My current MX4000 has a couple of scatches on the acrylic contrast screen so I therefore bought this from Lincoln B&o as it has a clean screen and a good deal too
How are you adjusting the stand on the 4000 .... with the stand option on the beo4 or with the on screen menu or is it an early one where you have to cycle the picture options on screen until it says sound?
Acrylic screen replacement is easy ... the glass ones are tougher.
I wouldnt quibble over the auction ... you got a good deal, even with it not working.  But these are usually straightforward to repair.
Neil
hi Neil,
I am selecting stand on the Beo 4 - then clicking OK and using the direction keys - but again this is on TV and there is nothing but static on screen
when you say easy - how do I get it off - does it click off or do I need to take the whole TV to bits
Think you are right about the deal
just bumping up - its make or break time for a refund :)
Have not managed to check this on mine ... what software version is in the TV?
To remove the screen ... if its perspex, put your finger nail under the bottom in the middle and pull out ... that's the simplest way.
To replace ... insert one side in ... then flex screen and then insert other side.
Neil
Hi Neil,
you are a legend my friend - swapped them straight over - it looks superb with a nice clean perspex cover on it  - although I had to use 2 polishing cloths as gloves :)
 Checked the menu and do not see any ref to s/w version - any ideas how to get it up? (no double entendre intended)
The software should be on the back of the TV, but if someone has swapped the cover this might not help.  On the Beo4, try the following ...
Press -> Menu
Press -> 0
Press -> 0
Press -> Go
Neil
Hi Neil,
Press -> Menu
Press -> 0
Press -> 0
Press -> Go
it is S/w version 1.1
as this is 1.1 - does this help at all with question 1 of my original post?
