MX4000 questions
I've just purchased a MKII MX4000 and have a few questions
1. As an early model the screen has the arcylic cover, can this be upgraded to the glass cover of later models? (in case my toddler scratches it....)
2. What products are OK to use to clean the acrylic screen?
3. it has a motorised stand and the bar floor stand, does the bar have to come off to fit the motorised one?
4. the screws to attach the stand seem to be missing, can these be purchased still?
thanks!
pb
1. Yes! The part number is 3451564.
2. I would be very careful! Nothing abrasive.
3. You have lost me slightly here! I thought the two stands were completely different!
4. They are small bolts. I had a similar problem with a TV and just bought some new ones at a hardware store.
you're a champion peter,
re the stands, yes it came fitted with the table top and the motorised stand was seperate. i was going to try the hardware if i couldn't get the seller to find the screws
do you have a ball park idea of the cost of the screen??? a guess would be fine
