mx 4002
hello
i need some help
i have had a mx4002 for some 11 years , and had it set up with my beovison 7 vx 7000 and a set top box and a 9000 be0-sound
it sadley died the other day , and as a stop gap  have bought a 2nd hand one a bit newer than the orginal one , it works ok , i need help in geti ng the vxux/vtape/dvd/ and sat functions to work on it , the master link audio is all ok
i can tne the tv in to the rf feed from down stairs on 799 and then control the item from the mx4002 , but a ssoon as i change function or turn it off it has no memeory of the function and if vtape etc is pressed only grey haze is visible
i would welcome amy suggestions on how to do this
You need to find the link frequency (799 in your case) and then save it as P60. In my LX you have to assign different sources to different frequencies but it would seem the later MX is simpler.
that worked at treat , i was stumped as it only went up to ch 59
thanks again
don
