And some more info. I can select through the app the ML sources TV, V.MEM, DTV, DVD and CAMERA. I cannot select the ML sources DVD2, DTV2, V.AUX2 and PC as well as none of the ML sources mapped to NL (RADIO, etc.). Any thoughts?
multiroom with ML/NL converter
Any more views based on the screenshot and additinoal info?
Elmer not sure about your system. I had to set my Beomaster5 to Audio Master for it to work with my Avant 55 and NL/ML converter. Once I did that it worked. I then added the Beosound 9000 (turn off the NL/ML, plug in your source, in this case BS9000, then turn on the converter, finally turn on the BS9000. I had to do these steps for each source, then I was able to connect and play my sources..I would suggest you try and connect one source at time, then others. Let us know how this works for you?
Thanks for your message. My setup is a lot easier - at least what I am trying to achieve first. I only have one source connected to ML/NL via ML, which is the BV7. I would then like to play NL sources from my A9 to the BV7 (e.g., Deezer, TuneIn).
I am facing two major issues:
1) I cannot play any NL source on my BV7 - neither through the Beomusic app nor using the Beo4 (selecting Radio). Screenshot below how I have mapped the NL sources. ML/NL is set to A-Master and A9 as primary
2) I cannot map all NL sources to the ML/NL (e.g., cannot map DLNA)
Any additional thoughts?
Let me rephrase the question. It would be great to hear from anyone using a ML/NL converter with a BV whether they succeeded to play NL sources from directly on their BV and more specifically whether one of these sources can be Deezer? Thanks for your help!
Things are often very quiet around here in the summer, especially August. I have a full ML network so I can't help. My BeoLink converter is setup as a "link" room - I use it to bring ML into NL, not vice-versa. Also, there's no Deezer in the US...
My understanding is that it should work as you describe (NL sources can "substitute" for ML sources not present in the ML) but there can be licensing issues that prohibit the distribution of audio..
I recommend patience, and possibly a "bump" to the thread in September once people get back from holiday if no one has answered.
Stan
This is my configuration. On the NL side there is a Moment connected, and in the chain of ML there is also a BV3 television.
For listening to any NL source on this ML equipped television I have to push first the LINK button and next choosing a NL source on the remote.
Thanks a lot. Let me change from A-Master to AV-Master and see whether this makes a difference.
Are you using the Beomusic app and have you tried to start playback on your BV3 from the app?
Tried AV-Master, but did not make any difference.
Your setup below is working with your BV3 (with Moment), so there is little reason why mine should work with BV7 (with A9). So, worth to keep trying...
Would be great if you can help elaborate what you mean by "LINK button". I don't have a LINK button on my Beoremote One and also not on my Beo4. Right now, I am "just" clicking "CD" (one of the sources mapped to NL), but nothing happens. It does not even play a CD (it plays the BV7 internal DVD though when I press DVD).
Thanks again for your help!
