mjmedlo wrote:
No
You can only control one product of the ML per converter.
They'll all carry the sound but the bro music app won't work unless it's connected only to one product.
I E use v aux2 on nl/ml to pull up deezer from the avant should be no problem on the ML SIDE
But, YOU WONT be able to see all the ML products on the beomusic app. Just not designed that way.
I opine that the beomusic app talks to ip addresses and ML doesn't have those.
The converter does and it distributes to everything on the ML but nothin singularly.
Only as a group.
He (mjmedlo) is correct.
A single convert simply broadcasts the audio along the ML network just like ML always worked.
You should be able to broadcast the Avant's audio to the ML devices.
If you wanted to manage the ML devices independently you would need a NL/ML converter for each ML end point device (including BeoLab 3500 or 2000 link room speakers).
You would also the NL cabling (dedicated cat6 or above) between each of the converters and also the Avant.
If you did go to that extreme, I believe you would also need the little ML plug that hangs off the nearest converter to give a link room speaker (your bathroom) an audio master "carrier signal".
As for converter software levels, the following screen shot gives the most recent saw level. If you are down level you should be able to download and upgrade the software yourself without using the dealer. Obviously take screen shots of all the configuration screens just so you can have a backup.
My HW version ...
Login to view imageMy SW version ...
Login to view image
