MultiRoom MultiNetwork questions
You might be able to log in the M5 in that network - best ask the admin there.
N.B. You don’t have to use the Bang & Olufsen app - only if you would need the built in sources.
As for TuneIn and Deezer, you can just AirPlay or Chromecast from their native apps.
But do remember, that anyone in that same network can AirPlay or ChromeCast to it then - do really want that?
The A1 is not a connected/NL device - it only works over bluetooth.
That would be the most flexible solution - just remember to turn it off, when you don’t use it.
If that - soundwise - is not enough for you, you could use the M5 in bluetooth mode ( = without the wifi network).
Isn't the "AirPlay Password" feature supported on the M5, to prevent this if you wish? This person describes how s/he got an *unwanted* AirPlay password (on the A6), and how to turn the feature off -- the screen shots look like that's the same spot in the BeoSetup app to turn it on...Had not thought about the problem of others possibly accessing it as you mentioned.
https://tomqb.wordpress.com/2015/12/28/airplay-passwort-fuer-beoplay-a6/
Maybe, never needed that myself.
But wouldn’t that require that you put in the code each time, you want to AirPlay.
Maybe some one else has experience with this stuff.
Not under Mac OS playing via iTunes, because the password will be saved in the user's keychain, if the "Remember" box is checked when entering it. Under iOS 12, the Music app just asks and remembers it without option. It also saves the volume level for each device. (Note: On the Mac, a lock icon appears next to the device's AirPlay Name in the pop-up list. No telltale icon on iOS, but if you delete the password from the AirPlay device, it just works. Yet iOS saves the old password (somewhere!?) because if you turn that old password back on again in the AirPlay device, the app works without enquiring.)But wouldn’t that require that you put in the code each time you want to AirPlay?
@trackbeo
Thanks - good to know, should you ever need it.
You can use both apps. Beoplay app is more for basic usage and Tonetouch settings. You cannot access Deezer using the Beoplay app.Reading the comments here as well as looking in the app store has caused me to have another question. Can the M5 be used with either the B and O multiroom app and the Beoplay app? It looks like it can be used with the Beoplay app? Is that just for Bluetooth or could I also connect it to wifi using the Beoplay app and use the onboard Deezer in the same manner as with the B and O multiroom app? Thanks!
