Moving order of products on app
Greetings all,
I just recently started using the app and adding products as the house build progressed and rooms were ready.  The products are not really in the chronological order that I would prefer, can they be moved around or is it a question of deleting products again and adding ‘backwards’ if that makes sense?
Will get some pics up soon of the progress.
Cheers
If you’re talking about the B&O app, then you can change the order
Hit the settings icon, then products, edit. You can drag products up and down in the list
Brilliant Sandyb thanks, just what I was after. Correct order now set.
The trouble is, that some users have a problem there.
Each time the app starts new, the default order of the devices is there again.
This has been reported to the app team - which has no solution to this bug.
Only when logging out of app I believe MN. If you stayed signed in the order remains. (I mit tilfælde i hvert fald)
Sorry - it is as I wrote —- don’t doubt me!
I have siscussed that with the team several times.
They have no solution, yet.
Vær du glad for at det ikke sker for dig ;-)
I stand corrected Sir!
