Motorized floor stand and table stands for BV 7-40 and 7-55
HI all,
I currently have a Beovision 7-40 with the original motorised floor stand, and I am now about to buy a second hand 7-55 with a motorised table stand and also an optional wall bracket.
My question is, can a 7-55 use the same floor stand i am using for my 7-40?
Are the various stands and wall brackets compatible between a 7-40 and a 7-55?
Thanks in advance
/Peter
Thanks for you quick reply Rob.
Too bad they aren't... :(
If you keep the stands but want to upgrade the screens, STB brackets now make a converter plate that allows you to use any set with VESA mount. You could for example fit and LG screen with a Beosound Stage for an alternative to the Eclipse.
Regards
Opman
