Motorised stand
I have just installed the motorised stand on a BV 10.
Just wondering how far the thing will actually turn from side to side? I was under the impression it could could a fair distance either side.
If I use the Beo4 to turn it it doesn't turn far at all. If I manually turn it to where I want it then if I use the stand function it will motor it back so it seems it can drive it that far. If I go into the stand menu the left/right perameters seem limited and I can get the stand to go any further.
Is there any way I can reset the stand?
On another note is there any way to load new devices on the PUC controller without a dealer? Can it be done via the web or USB?
Peter
petermc wrote:
Peter
Hi!
Yes, you can set new parameters. I had to do it because I had an obstacle on the left side. Don´t remember exactly but I was helped by usermanual
