Motor stand for MX7000
Could anyone tell me if it is possible to use a motor stand MS 4106 on my MX 7000 TV or does some one have a stand for a MX7000 who could photograph the adaption plate so I could fabricate a new one ?
The MS 4106 looks identical to the MX 7000 unit but the fixings to the TV will be different.
Jack
Jack, I believe the motor unit is the same on all MX, LX, LS and L models. It is just the plate that is different. They all seem to have the same connection for the motor.
Craig🙂
Slight correction ... the MX8000 and MX4200 stands operate differently and there seems to be a compatability issue with some MX5000 stands.
Neil
Thanks Craig
The motor stand does work with the MX7000 I just need details for the adaption plate.
Jack
Jack, it might be worth dropping Nobby a PM knowing Neil, he may have the one you need in stock.
Craig🙂
BTW, it was nice to see you again over the weekend😕
hi jack,
 i have one in front of me, i can add a photo if it helps,
do you have the smaller mx4000 version to compare to? if not ill check it against one i have in the showroom tomorrow, the holes for the motor will be the same, let me know what measurments you need
jason
Jason
Thanks for your reply, the stand I have is off a LS5500 , a photo would allow me to see where the screw connections are located.
Thanks again
Jack
 no problem jack, the 4 raised holes on the edges fit the tv and the 6 small holes in the centre fit the motor,
hope this is what your after, or as craig said im sure Nobby should have one if you need one
regards jason
Thanks Jason
The photo is a great help, I have a MX7000 TV. Could you measure the overall width and length if the plate and the measurement from the turntable centre to the front edge of the plate.
The centre distances of the mounting holes would be very useful.
Thanks for all your help
Jack
No need to measure, this is the correct one for the 28inch MX
Neil
