Moment network
Hi
Having issues connecting my moment to a hardwired rj45 network cable rather than wifi
Are there settings that i need to alter - i only see the available wifi networks to connect to?
Thanks in advance Andrew
Hi, when you hardwire the moment it autodetect the network. Wifi is still needed for the jukebox to communicate with the soundheart, thats why you still have to give in a wifi connection. You can see in the beotool that your moment is wired
Hope this helps
If the SoundHeart is wired, the ethernet connectivity has priority over the wireless.
The Jukebox is wireless only, 2,4GHz band only.
The use DHCP setting is on
Is this correct?
Maybe you can provide us more details ? To what kind of equipment have you connected the SoundHeart via Ethernet? Do you have a mean to check if the equipment port you connected the SoundHeart is up and running? If not have tried another cable ? Etc ...
