Moment can’t find WISA on BL90
Just got my Moment. Could someone with more experience and know-how please help. Spent all evening trying to get the Moment to connect over WISA to BL90. Often it can’t find any speakers. Rarely it finds left channel but right channel not visible to select. Pulling my hair out. Tried factory resetting twenty times. BL90’set to WIRELESS. Login to view image Login to view image Login to view image Login to view image
Congratulations with your BSM!Checked my Moment and the BL90 are not on the list for wired connection. Might it be that your complex BL90’s have to be in a different mode? As they have to recognise the WiSa signal from the Moment. In your picture a automatic option show’s, did you try this? Does your BL90 installation menu give you an idea? Sorry I cannot be of more assistance. Hope you solve it quickly!
I would not run these beasts wireless anyway.
Just get over it....and wire them!
I would first update the Moment software, yours is very old, pre BL 90 for sure.Mine has the latest for reference: Login to view imageUnfortunately some have some trouble with the latest code, but some haven’t, like myself.
I’m too scared to update the software. Aren’t the latest problems due to those that have TVs and linked multiple products?I would first update the Moment software, yours is very old, pre BL 90 for sure. Mine has the latest for reference: Unfortunately some have some trouble with the latest code, but done haven’t, like myself. BS Moment, BS Core, BS Ouverture, BS1, BL18, BL19, BL8000 + RCV1, A6, M5, M3, A1, H5, TR1
Mine is on the same software and have no problems with it. Just checked and the BL90’s are not in the list. My guess is that the BL90’s don’t need to be on the list due to their own advanced OS. The output on the Moment is either wired powerlink or wisa, so first try to hardwire your master BL90 with powerlink and see how it works. Then try to setup a wireless connectionI would first update the Moment software, yours is very old, pre BL 90 for sure. Mine has the latest for reference: Unfortunately some have some trouble with the latest code, but done haven’t, like myself. BS Moment, BS Core, BS Ouverture, BS1, BL18, BL19, BL8000 + RCV1, A6, M5, M3, A1, H5, TR1
Hi Millemissen, why would you powerlink and not WISA them please?Surely, a digital link is better than converting it to analog in the Moment then sending them to BL90 which converts the analog into digital and upsamples into DSP then to the individual poweramps for each driver. An unnecessary conversion from digital to analog to digital then back to analog.I would not run these beasts wireless anyway. Just get over it....and wire them! MM There is a tv - and there is a BV.
Mine is on latest software too and no problems. The Moment is connected to the TV and uses my BL’s that are wisa connected to the tv. Indeed update your Moment and first try to wire your master BL90 through powerlink.I’m too scared to update the software. Aren’t the latest problems due to those that have TVs and linked multiple products?
And if you don’t update you’ll not receive support from B&O I’m afraid.There are chances that your BL90 will be pairable with the Moment after the update and you’ll also benefit from the Expert mode where you can control the DLNA updates and avoid continuous harvesting like one of your sceeen is showing and which is a pain with large libraries.Mine is on latest software too and no problems. The Moment is connected to the TV and uses my BL’s that are wisa connected to the tv. Indeed update your Moment and first try to wire your master BL90 through powerlink.
