Hi all,
I recently purchased a used mlgw type 1799 and had everything working perfectly. After about 3 weeks of use, I noticed it wasn’t connecting to my network. I tried to reboot and reset but can’t get it to connect and can’t access the web interface. When I turn it on, the green light is on for about 2 seconds and then goes solid red and stays that way. I did open up the case to see if there was any visible issue with the electronic components but don’t see anything obvious. I can’t find any specific info regarding my issue and hoping someone on the forum may have some ideas on the issue and how to fix it. When I originally set it up I updated the software and all my components works great. Not sure what went wrong. Any help would be greatly appreciated.
Bud
