It's some years ago but for the Cable i remember i solder a simple 1 wire txd mlgw to rxd somfy rts and 1 wire gnd thats it
i see if i had the programming for the customstring on mlgw and get back
I don't notice that problem iwas rs485 on european rts, this was some years ago and i use a US model with rs232 but maybe it's possible to use rs232 -> rs 485 converter maybe? or buy US model because RTS transmitter use 433,92 mhz in US also i not sure now but probebly the same
You only type in for example 0103U in match/command field in mlgw = RTS adress 1 motorchannel 03 (1-16) and motor UP
or 0103S in match/command field in mlgw = RTS adress 1 motorchannel 03 (1-16) and motor stop
or 0103D in match/command field in mlgw = RTS adress 1 motorchannel 03 (1-16) and motor down
all as output command in type field in mlgw
/Tompa
yes rs232
and i wrote wrong in earlier post (433,92Mhz )but somfy use 433,42Mhz but it's the same in US and EU so it would be no problem to use the RTS universal interface II US model in europé (and that was the interface i used)
/Tompa
