Ml to nl convertor
What are your thoughts on the above, i have an older masterlink system comprising of, 3200 connected to lab 4000 and lab 2, i also have two passive kits upstairs and after xmas in the garage i will have bvis 732 connected to lab 6000, are there any advantages adding this to my system
Well only if you add a NL based item!  Maybe though if you want to use the BeoLink apps...
I use one to bridge between a Beosystem 4 and the rest of my ML based systems.
Hey thanks for the reply, can you it for anything like spotify or is there any nl produts you would recommend?
