ML/NL converter used with only ML products, just to give access to Beo APP
This thread may answer some of your questions
Further to Madskp's link above, I asked a similar question a while back and a Beolink Gateway was suggested as a better alternative. The thread is here:
Hello to everybody
I would like to know if it's possible to interact with just "old" ML products with Beo APP using ML/NL converter.
I explain better: I don't have any new product using NL, I owe the followings all connected with ML:
BV7-55 MKII in the main room (actually with DVB-T module, usable in Italy still for a short time because we are moving to HEVC DVB-T)
BV7-32 MKIII in a bedroom, without any DVB-T, Chromecast
Beolab 3500 in the bathroom
Beolab 2000 in the kitchen
I had also a Beolink PC2 but since a few days is dead, it was used to distribute NRadio and NMusic to Beolabs.
I assume that introducing an ML/NL converter, I could join the ML to my wi-fi net, and so to Beo-App.
Due to the fact that Beolink PC2 is dead, actually in order to listen Radio on Beolabs, I connect them to the Radio Channels received with DVB-T on BV7-55, using Beo4 and the sequence DVT --> red button. Doing so, nobody can look at BV7-55 at same time.
My idea is to send NRadio to Beolabs by means of Beo App, but I'm not sure if NRadio has to be supplied by an audio master (that is no more present) or if the App itself can generate it.
I will appreciate so much your comments.
The BLC NL/ML doesn't have any in-built sources. It can play (with attached speakers) or pass-through NL and ML sources and anything connected to its "line-in".
Therefore, to get streaming to your ML you either need a NL device or a streamer hooked to the BLC's line-in. I'd recommend getting a 2nd hand BeoPlay M3 and put it in a bathroom or some other room that currently doesn't have music and can live without hi-fidelity. If you have no need for another speaker anywhere in your house, just stick it in a cabinet.
In this way, your M3 can be the source for B&O Radio and Deezer. You can control it with the B&O app and play it on any of your ML equipment. If you don't want to listen to your m3, set the default sound level to 0 or mute it. You can also setup the BLC so that unused Beo4 buttons can be mapped to the M3. For example, "CD" (since it doesn't look like you have a CD player) can be mapped to B&O radio on the m3 and sending CD to your BS3500 will automatically start everything required to listen to it. You can skip to the next/prev station/Deezer song using the Beo4 arrow keys (similar to the BeoLink PC).
I do this (mute NL device and listen through BLC to BS9000 + BL1) quite frequently. It's better than driving it strictly with your phone (for example as would be the case with Bluetooth) because you can use your phone for other things (like talking on it) and it doesn't impact the music.
You cannot distribute Spotify because of licensing restrictions. Not sure about any other streaming services, but Deezer definitely works.
Hi everybody, many thanks to all of you, sorry for my late answer I was abroad.
Beolink Gateway is too expensive and too difficult to be programmed, I probably will proceed with Beoplay M3 as soon as in Italy we will have the switch off from DVB-T to DVT-2 HEVC, so BV7-55 will be nomore able to receive broadcast radio stations. Final switch-off has been announced many times but always procrastinated.
I have a pc2 that’s not been used for years if you’re interested ?
An option I am using is an Apple AirPort Express hooked up to a 9000 cd player that’s on masterlink , and once masterlink is on the home network you can stream to it .
Once you get that ML/NL converter set up, your ML gear can hop onto your Wi-Fi and be controlled through the Beo App. And about streaming NRadio to your Beolabs, I think the Beo App can handle it solo, no need for an audio master. It should whip up the stream once you've got everything sorted.
And about streaming NRadio to your Beolabs, I think the Beo App can handle it solo, no need for an audio master.This has not been my experience. When I choose a B&O Radio station while having my BLC selected, I get a Something went wrong" error.
In my BLC NL/ML, the following sources appear. Words [between square parentheses] not displayed by the App, and added only for clarity:
- CD [from BS3000]
- N.MUSIC [from BS5]
- N.RADIO [from BS5]
- B&O Radio Beoplay A6
- Deezer Beoplay A6
