ML do not see my new audio master after removing BS 5
My ML do not see my audio master after removing the BS 5, while waiting for my Moment to arrive I wanted to use my PC2 .
I thought that this will be a simple 5-minute operation, taking it out from the box ( I have not using it since I bought the  BS5 ) and connect to the ML, to mac mini with BMLink and press Nmusic…………nothing.
Probably this is something easy to solve or ??
The PC2 is working when connecting speakers directly to it, the problem is no distribution in the ML.
When I press CD, Radio Amem2 ,Phono, Nmusik,  Nradio………..depending on the equipment in the link rooms it should start but nothing.
Any suggestions.
96 Normal 0 21 false false false PL X-NONE X-NONE
G
What type of audio master do you have now? Could be that the ML is not feed with any power now when your ordinary master is removed.
Ok, now i belive that I understand , the PC 2 is not an AudioMaster , its only a box for Nmusic and will not work without a AudioMaster, soo i guest that i have to wait for the Moment or buy a used BS 2500 or similar.
thanks
G
Which Option was/is the PC2 set to?
2
but is the PC2 a master?
2
I'd try Option 6, but no guarantee - it is a long time, since I played with the PC2.
And power-on/power-off your masterlinked devices before you start using the setup again.
thanks
G
A BS2500 is not capable of N.Music, you need at least a BS3000/9000 with certain sw level, check this forum for details.
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
thanks
G
In the archived forum a solution is given:
/forum/imported-unmapped/beovision-10-32-inbetriebnahme
Ralf
